RCU Forums - View Single Post - JR Matchbox end point programming
Old 10-05-2014 | 03:20 AM
wfield0455's Avatar
wfield0455
My Feedback: (7)
Originally Posted by turnnburn
Unless I am missing the boat some how (which I very well may doing ) the 12x will not transfer control to any slaved functions. I just got my F-86 out, I have wheel brakes fixed with down elevator on the master. When I transfer to the s alve the brake no longer works. If I get a chance to I will do he the same test on my old 10x. I really dont expect it to work either. Maybe I m doing somtig frr
Thanks to Randy and everbod y else who has contributed to this thread. ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,
Yup, I think you are missing the boat I had a 12 channel receiver in my Boomerang XL, all controls on separate channels, controlled by a JR12X, and buddy boxed with a Spektrum DX8. It worked perfectly. The instructor did need to control the flaps and gear but the student had full control of everything else. I have since switched the transmitter to a Spektrum DX18 and tweaked the setup slightly so a student could also control the gear and flaps as well. When the trainer interface is activated, the instructors transmitter should be simply seeing the stick input (4 primary controls) from the student transmitter but the master should still control the mated channels, mixes, etc. There was no need to duplicate the mixes, etc in the student transmitter, I used a basic, default, airplane setup in the DX8.
