RCU Forums - View Single Post - Converting engine to run on E85 - smallest size that would work?
Old 10-05-2014 | 09:18 AM
mranga
Default Converting engine to run on E85 - smallest size that would work?
I am itching to tinker with a E85 conversion. I have a few old engines in the drawer : 46, 52, 60, 120 I'd like to try one of these out. OK I understand it is probably not worth the cost in terms of fuel savings etc. (46-60 engines are not that fuel hungry and I don't fly that often).
From another thread on this forum, it appears that E85 conversion is straightforward. I don't need a new carb. All I need is an ignition module and magnet. The fuel oil ratio stays the same. I can use Castor in the fuel oil mix.
I'd like to know the smallest reasonable size that one should attempt to do these things in order to have a chance of success. How much weight would the ignition module and battery add? I plan to put it on an Eindeker so plenty of wing area.
Thanks for you insights.
