I got a bit bored with paint stripping, sanding, priming, sanding, priming, etc so I decided to work on something else for a bit of fun and inspiration. I used a length of 3/8" plastic tubing to create a fairing on the rudder for the white navigation light. To snake the wires through the fin, I cut a hole in the top of the fin about 1-1/2" from the rear and a hole through the rib over the rudder servo and ran the wires down to the servo area.
The Model Master acrylic paint arrived so I set to work painting the Sundowner scheme on the fin/rudder. Hopefully that will motivate me as there isn't a lot of time left until BITW.
Regards,
Jim
