2FAS,
Thanks, I'm looking forward to having it done too as I have a couple of other projects that need attention. Yes, the plane is fitted with DreamWorks Taurus retracts and DreamWorks Pro-Link trailing link struts fitted with Interairco wheels and brakes.
Installation of the gear doors was pretty simple as the door is mounted on the flat outer face of the upper strut. This evening I installed the belly fairing which I had modified to remove the unsightly gluing flange, and I added balsa supports to keep the fairing from "oil canning".
Regards,
Jim
