You can have a fuel dot with a three line system. The dot is connected to the down tube. The carb to the felt clunk pickup and the vent tube to the muffler tap if there is one with the pumped carb, if there is not, the vent simply gets an anti siphon loop and then is fixed in place to discharge overflow usually below the plane.
