Hi Roger,
Thank you for the info. It is a good head-up tip. I Wonder if I could gain 1,5 cm to 2,0 cm by mounting the engine mount from the Inside of the firewall.
I was thinking that there was space for an FG-40.
How much space left on the right / left side between cowl and engine?
How much weight did you add to reach acceptable CG with a FG-36?
Merci & Keep your stick on the ice... eh
Marvin
I will wait for the Gears. Here in Europe the Retract: Spitfire Mk IX (EFLG625SP) retails for 350.00 EUR.... (492.00 CAN) EH!!!
