Also, I know it is too late really to make any adjustments, but washout will be your friend. If you have an incidence meter, it would be easy to check. A couple of degrees will help greatly with your stall if the wing loading is high. Learned this big time when I first started flying the 1/12th scale combat models, that all suffered from a high wing loading as well, and had to be hand launched.
