Originally Posted by
speedracerntrixie
+1 I disconnect it as well but leave in place. The carb throttle shaft needs the spring pre-load. There are many options here. The thought is that if you leave it connected in the event of a linkage failure the throttle will come to idle or off. With the use of an IBEC you have the availability to shout down the engine at a flick of a switch so no real need for a mechanical safety. IMO most guys go cheap on the throttle servo so being under load all of the time might shorten the servo life. I emphasize the word might here as I have no evidence of this. When it comes to gassers there is a very wide spectrum of opinions on how to do things. If you want options, ask your question and then select the option that makes most sense to you.
I fully understand : Six of one / half dozen of other ! LOL
