Ray,
Here is what my Fleet looked like when I acquired it. The original builder did the one piece wing set up for both top and bottom. As you can see, the rear landing gear block is in the fuse in front of the leading edge of the wing! Bad, bad! I relocated the LG block to the proper scale location on the wing. The wing dowel pins were OK so I left them alone. Cleaned up and replaced the center section sheeting and made sure everything was smooth.
Jim
