Well, Andy is essentially done on the build of my 190....It came out flawless....has Sierra all the way around, on air; has a IFlyTailies cockpit kit; a Cortex Demon gyro, a Down&Locked IBEC so I'm only running two batteries on a Powersafe 12ch, with an 8 channel add-on module, and full Telemetry setup. It came out about 1/16" nose heavy, with zero lead...nice....even put an air gauge under the cover. Here are the final pix....I'll pick it up tomorrow, and start with the Callie Graphics package and ProMark Fuselage/maintenance markings sheets. They will really top this off. I'm actually mixing some of the decals from two different full scale models. But the main look will be the "Eagle". And I've got to "spiral paint" the spinner.
What do you all think of the black/white spinner that uses a 1/3 solid white block on the black spinner, vice a white spiral....it looks pretty cool actually, but different.
