Originally Posted by
danlrc
Holo, Eric,
On my big RC sailing ship models, I learned a long time ago to fuse all the circuits because of rigging snags, etc. I fused my KT and Tiger1 at 5A and have not had a blow. Easy and cheap to install and you can start with a low amp fuse and go higher if necessary til you find a stable fuse value. Keep fuse value below slip ring rating and all should be OK I think.
Here's a pic of a simple, small fuse setup. ATM fuse, female blade terminals on wire ends, heat shrink terminals. Almost any value fuse is available.
Good advice, but the Leo DMD will protect with its own current limiting output protection on the FET's. The max momentary surge on the FET's is about 20A, so continuous would be about 10A max, but RMS continuous would be more like 7A under stall.
