Originally Posted by
rustyus
When I was updating; downgrading; whatever you want to call it, the steering knuckles...I wasn't sure which hole to put the ball studs in. The EXT manual says outside hole, ST manual says inside hole; VW says inside hole; EXT2.4 shows inside hole....
I'm just curious to know where any of you have their ball studs mounted. And I am used to a graphite knuckle with a ball stud hole closer to the axle (shown in red).
And when did Tower Hobbies (Hobbico) get their own
SC 4wd? It's not out yet, but looks like someone has put some thought into it and looks promising...I like to root for the underdog.....
I am using the outside holes on the EXT arms/knuckles at the moment. Seems to be working well. My thought process tells me the inside holes on the steering knuckles would give more leverage to turn the wheels. Is that a correct assumption?
Just got TH Speedmart flyer in mail...front cover has the TH
Cutback 4wd SC truck on it. I can't wait for a
review or a long term review.
