RCU Forums - View Single Post - Parallel Gripper Kit - $14.99
Old 10-17-2014 | 06:04 AM
ServoCity's Avatar
ServoCity
Default Parallel Gripper Kit - $14.99
Get a grip! The first in our line of standard size gripper kits is here. The Parallel Gripper Kit A is a simple, durable, and versatile kit that is great for all kinds of robotic applications. The grippers move towards one another in a parallel motion, hence the name, and have a maximum width of 2.80”. By incorporating the Actobotics 0.770” hub pattern into the back plate, and 1.0607” hole spacing on the grippers, you can easily attach nearly any Actobotics component to the assembled kit. Designed for use with any standard size Hitec or Futaba servo (sold separately). The kit is easy to assemble and requires only a Phillips Head Screwdriver. Watch our step by step assembly video for detailed instructions.
Actobotics Parallel Gripper Kit A (for standard size Hitec or Futaba Servos) - $14.99
http://www.servocity.com/html/parall...a__637092.html
Assembly video: Standard Parallel Griper Kit Assembly (Full Instructions)
More gripper kits coming soon: http://www.servocity.com/html/robots___accessories.html
