Many gas flyers use the felt filter clunks, but to be effective as a filter for the carb, you really need to run a 3 line setup with a separate fill/drain line, or elese you're pumping possible debris into the wrong side of the filter. I run three line setups with felt filter clunk on all my gas engines.
Pete
