LOL! Nice to know I'm missed. After doing much work actually had a minute to take the wing outside and give it a good going over, visually. I am not happy with it, it appears the clear was harder than the paint and the sanding process left very minute lines visible at the right angle. I am going to do another redo on the top wing's top, remove covering and repaint, (yes!) again. I have worked out the kinks with the vinyl and such so the next time should be the cats meow. So, I am taking a long break on the Pitts and getting some work done on the MH. My room has had the knockdown applied and primed, and the door is in as well, need to do a little trim work before painting. By the end of next week I should be able to start installing the shop stuff and unload all the tools and stuff from the toy hauler. That will also make assembly a bit easier, having tools that is. So I figure I will get back to the Pitts in another couple weeks.
