Carlos, it is very possible. First, changing you fuel/oil mix actually leaned the fuel/air ratio that the engine sees. Second the more oil can give you a better ring seal. Third and this one has to be seen to be believed is that the carbs are calibrated to run the higher viscosity fuel.
