Originally Posted by
drac1
Hi Guys,
My YS header keeps coming loose. I have tried different methods to try and stop it from loosening, but nothing has been completely effective.
Does any one else have this problem? Also, those of you that don't, what is the method you use to keep them tight?
Advice appreciated.
Regards
Scott
Hi Scott,
On my gas engines' exhausts I use Loctite Ultra Copper high temp gasket maker. It has worked very well. But I don't know if it would work on the YS. Similar exhaust temps between the two types of engines. I would just add a thin layer to the nut, snug it down and let it cure for 24 hours.
