RE: Y cable (aileron) Problem/solution
Strange.
Almost sounds like there was a problem with the connector on the "Y" when you plugged it into the Rx. Maybe a corroded pin or something. Then, when you removed it and put a new connector on the Rx, it wiped some of it away.
Did you try just the "Y" again?
Dennis-
