Glassed up the inside nose of the plastic cowling to reinforce it and will continue on the sides tomorrow. My buddy Gerry has a trick up his sleeve to really clean up the gaps as the leading edge of the flaps. A fowler flap set up would have been too much work in such a small model. Because of that the hinge line leaves some to be desired using the torque rod actuation. It's not bad but it will be real good when done. More pictures tomorrow.
