Originally Posted by
Capt Lou
I need help with a Saito 125. It's a new engine that I installed in a Great Planes Decathlon (Giant Scale 89" Wing Span) kit. The engine is installed inverted with a stock muffler but right angle (90 degrees) manifold. I use Powermaster 20/20 fuel and a 16x6 Zoar wood propeller. I have broken in the engine with about 1.5 gallons of fuel and it runs well with a good transition from low to high. My issue is that I can only get about 8600 RPM's at full throttle. I called Horizon and they told me that 9000 RPM's is the max I should achieve and that 8600 is the low end but not necessarily bad. I have find tuned the low end idle and that is running perfectly and I can tune the high end but only at a max of 8600 RPM's. Can anyone tell me what their experience is with these engines, especially maximum RPM's. Also, has anyone used a 17x6 propeller to improve the RPM's? thanks in advance for any assistance. Capt Lou
I don't believe the 125 will pull a 17x6 prop. I have a 125 that was purchased used from Jim and I run a APC 16x6, it will turn around 9000
