dgliderguy,
thanks for the quick response. Sounds great! Congrats!
Close to the fuselage I measured exactly 0 degrees of the upper and lower wing. At the ailerons I got -1.5 degrees at both, upper and lower wing! That is totally different from your measurements. Anyway, I'll try the maiden flight with this wing set up...., but I'll move the CG from the lower leading edge approx. 20 mm forward.
Hope, that the upcoming winter will give me the time to check the setup out within the next three weeks....
