Originally Posted by
masupilami59
yes, the twist is absolutely symmetrical - on left, right, upper and lower wings. Sure, its my conservatism to move the CG a little bit forward. But, maybe it is better to leave the CG at the position you recommended. So, I am curious how the plane will behave, as the incidences are different from yours.
Anyway, I will check it out and will drop some lines here when I made my experiences.
Balance her right at the bottom wing LEADING EDGE. Full Scale Pitts has the CG in the same position as most biplanes do, mine has about 100 flights on it and going strong, still looks new with no scratches or signs of wear.....fun bird to have in the Hangar! Good luck on your Maiden and take it easy on her until you learn her traits!
