I thought the cat was going to play hide n seek with the tank.
Originally Posted by
maxu52
I've put quite a bit of run time on them and they haven't gotten much better. One unusual thing is that when they were new it was almost as if the pins holding the links together were too small in diameter. After running a few yards they would start to work loose and allow the links to separate. Erik sent me a whole new set of pins but it was the same thing. I finally had to flatten the end of each pin to get it to grip and stay in place, but I still have trouble with throwing the track at the left idler, and you can still hear them popping and clicking when they run. If I have to I'll go through them link by link, but I was hoping not to have to do that. I'm wondering if something went wrong during casting these inks, like maybe cooling to fast or too slow, or something like that. I can't think of any other reason for the holes to be too big. It's been suggested to try adding or subtracting a link, but with these KT tracks it's not that simple. You have to add or subtract TWO links at a time because of the design, and that makes a huge difference. I think it was Strato50 that suggested stripping the tracks of paint to see if that helps, so I might do that first, but you know how it is trying to find the time. That's one of the reasons that I sometimes hesitate to ask for help here, because the guys always try to be helpful and have great ideas, but then if my lazy butt doesn't get to it in a reasonable amount of time I feel bad about it. I'm also tempted to just buy new tracks, but that would be a very expensive fix, and I'd much rather spend that coin to upgrade to a hobby grade Tx/Rx. But I'll keep plugging at it and I'm sure I'll figure it out eventually. After what you had to say, Dan, I think I might try setting it on blocks and just running it for a half hour or so to see if that makes any improvement.
How to solved the clicking noise? I imagine that's the sound of the tracks teeth hitting the idler wheel.
