Acetone
It can also be used to wipe CA spills off Monokote.
It also is used to thin epoxy glue. It's better than using rubbing alcohol as the alcohol has water in it which weakens the glue. If you want the thinned glue to have strength, the acetone doesn't degrade the strength. Since it's pretty cheap and alcohol won't wipe CA spills.............
