Originally Posted by
Max2011
Seems to me you could program different gains....different than the "normal"(amber light) onto the HH(red light) if you do not intend on using HH. Still you would need to use the computer to make indiviual changes but you could use the 3-position switch to see the difference in the normal setting and your new gain settings.
Absolutely! Bank one is Amber and default is rate mode, Bank two is Green and default is heading Hold, Red is OFF.
Depending on your radio you could have as many different gain as you like, you can setup rate and hold settings in each bank for one or all of the Axis' by using the PC software. Jeti radio users are using a pitot sensor to change the gains setting in flight automatically. This unit has great flexibilty!
