I have had success with the alumaweld by making the muffler fit together mechanically. I will use overlap joints and screws to secure them. I typically use thin wall rectangular aluminum and only have to secure the ends. Make sure you use crush tubes for the fastener holes. The problem with the muffler coming apart is not the with the braze, but with the vibration. Good luck, red
