H9 Tiger Moth Wing Supports
Here are a couple of pics of a solution that a few of us use. The blue foam seems to work well and holds the wings in place while attaching to fuse. The other end is attached with servo mounting screws and a piece of ply over the existing tube.
We don't use the rubber bands!
Three of us have had the ply tang that holds the wing on break loose. It is a good idea to use some CA to make sure it will not come out.
