Hay Grosbeak,
Yes...one must be careful with the glue overage on assembling the bits and pieces to the model. I used Titebond III on my airframe and I needed to keep a damp rag near me to wipe off all excess glue. When I assembled the fuselage, I had to use glue that was slower drying then even 30 minute epoxy, to get everything together properly. The booklet will ask you to use epoxy in some places and I did as much as I was instructed to do, but due to living in the tropics, the warmer air caused the epoxy to dry up twice as fast...some times even faster then I could properly assemble the parts, before the epoxy set up.
Great pictures...
Soft Landings Always,
Bobby of Maui
