RE: Care of CA Containers?????????
I do the same thing as Pushrod. Use the applicators, it makes a great way to direct the glue out of the tube in in the exact spot where you need it. And it reaches areas where you can't get the CA container. I keep mine applicator tip up in an empty pill bottle on my bench with about 1/2 of the squeeze part filled. It's great when you are gluing and need it for a spot here, and there.
