RCU Forums - View Single Post - Airspeed warnings
Old 11-03-2014 | 03:23 AM
weatronic Support's Avatar
weatronic Support
Hello to all weatronic user, followers and anyone else
Hello Edgar,
you can set a Maximum Warning. If you
reach it you get the announcement: Warning MUX Speed XXX Km/h (Example). This Warning you get one Time! The thought here is you hear the Warning you decrease the Speed and all is good. If you again get over the Warning value you get again the Warning.
The same is at the minimum Warning, example Landing approach. You set your Minimum Warning at 50 Km/h. You are at the approach and get under the 50 Km/h you get the Warning. You increase the Speed. You get again under the Warning Value you get the Warning again. Now you are at the Landing, you don´t want to hear you are to slow, because for the Landing the speed is good, or you are breaking.
I hope you understand what i try to explain
Kind regards from Berlin / Mit freundlichen Grüßen aus Berlin
Jens Ackermann
Service Manager / Leiter der Serviceabteilung
