RCU Forums - View Single Post - Extra 300S Build
Old 11-06-2014 | 05:46 AM
scale only 4 me's Avatar
scale only 4 me
My Feedback: (158)
Originally Posted by GHartman
There's not enough structure near the tail to move the servo's to, I would if the structure would support it, I would have to rebuild the tail section to have a solid balsa wood structure. The fuse in not solid balsa wood.
I moved the engine back once, the fuel pump is hitting the motor mount, I could gain about 1/4" if I were to shave the motor mount to allow the fuel pump to fit closer to the firewall.
I see where you guys are going with finding all the weight in the nose, the cowling, prop and spinner weigh 10 5/8 oz. I have pretty beefy screws and nuts to secure the engine to the mount. The prop is a K-series Master Airscrew 15 x 8, can use 15 x 8 to 16 x 6 props with this engine. How do you go about getting a lighter cowling?
I think relocating the battery towards the tail shouldn't be that difficult.
Yes, the moving servos would take some work.
I think cutting in like GB has done, then making a hatch for battery access would be very easy, or just patch the covering once you like the battery placement. it would be very unnoticeable on the bottom of the fuse.
good luck
p.s.
I too have had those spinners blow up on big 4 strokes myself, it happens when the prop slips on an engine backfire,, be cautious.
