Hi,
Post #4 shows the fuel tank wrapped in foam. It tucks into the motor box.
Are the kit contained nylon bolts OK to use?
Not my fuel valve....... I could at least move it back.
I ordered a new motor mount mentioned by RICKSTUBBZ.
Tap the engine holes directly into the basswood/plywood ?
Should/Can I remove more than a 1/4" from the motor box? I have plenty of lead way on the cowl.
