Wing jig
Once it dawned on me that the upper jig support was at the wrong incidence angle I modified it to match the wing as assembled. It is now glued in place.
- With that done I can now slip the jig into place with the wing still on the plane.
- Added some thin shock cords instead of the original rubber bands.
- Pulled the wing assembly out.
- Inserted a vertical piece of a "Lowes" yard stick with small block spacers pressing against the jig to prevent it from slipping out of place. I also slid a wire push rod throught the tab holes to keep it in place.
- Needless to say I also added the wire cross rigging at the wing struts which are not in the picture.
The pictures are self explanatory but your comments would just make it better.
Rafeek
Reason: Clarification
