RCU Forums - View Single Post - UMS Evolution Radial Care and Operation
Old 11-07-2014 | 06:54 PM
  #1314
chorner
Adrian, do you plan to design a new magnet & sensor ring that is adjustable and screw mountable versus having to JB weld the sensor pickup wire onto the sensor ring? That combined with more compact ignition unit boxes would convert me over to using your CH ignitions system. That way customers can easily and reliably setup the units themselves without fail.
For everyone else... I've got a ~28-30lbs plane (the Hangar 9 60cc Corsair I mentioned in a previous post) and the Evo 7-77... I'm wondering what the best propellor is? I'd like as close to 1:1 thrust as possible with speeds of at least the 54-60mph range. Does this engine have the torque and HP to pull those kind of numbers? How fast is it turning 24x10 Xoar props for example? Would a 23x10 3 blade work and provide ~30lbs of thrust?
