Maiden preflight tuning, result 1 then 2 failed hs 635 servos
I have been building a cmp 140 mustang for a number of years now and finally finished it this weekend. It has a magnum 180 fs which gave me a bit of trouble initially but is running great now. During this time the motor was running very roughly and I noticed one of my ailerons was not moving smoothly and upon inspection it had stripped the gears around the neutral position.
I continued with my tunning and then noticed the same from the other aileron, so now both aileron servos have failed in the same way. and yes they where fine before, what would be a good servo to replace these HS 635hb as I don't trust them now?
thanks Greg
