RCU Forums - View Single Post - UMS Evolution Radial Care and Operation
Old 11-09-2014 | 05:12 AM
  #1325
CH Ignitions
@ Chorner:
I will look into that. But that will be much more visible as parts will have to come some how from the case, hanging ...ETC.
But ...I will do it and have an option for scale and non scale option.
Current version is hidden behind the prop.
As far as size I will try to make it as small as possible .
The unit has 7 ignition coils that are 17.5x17.5x20mm... so will be a matter of placing them.
7 in the row will be a longer box, if arange 4 and 3 on top will be taller. if put 4 on one side and 3 on the other then will be wider.
On the Air frame you guys install those engines...what/how much room do you have . If I make it...I will try to make it to be easier for you.
I will come back with some cad options in a week or so.
Adrian
