Originally Posted by
JohnShe
So you are still trying out your failed mind reading act? The interpretive rule gives no indication that the FAA wants all airports to shut down nearby model aviation airfields. The only restriction that the FAA has stated is that of endangering the NAS. They clearly state that, if model aviation conducts itself according to the AMA, or other CBO, safety guidelines, there is no reason to restrict model airplane operations.
Though I am not convinced that the FAA wants to shut down model operations within 5mi. of all airports, I think the wording in the interpretative clearly states that the airport operator at each airport has the authority to decide if model aircraft will be flown within 5 miles of the airport, even if the model aircraft are being operated under CBO guidelines. It is not clear whether or not model aircraft pilots could appeal the matter to the FAA, or if the FAA would be likely to overrule the airport operator's decision.
