RCU Forums - View Single Post - What do you do for a muffler
Old 11-10-2014 | 06:30 AM
av8tor1977's Avatar
av8tor1977
I don't worry too much about the volume as long as the exits are large enough. But then again as you mentioned noise is not an issue for me. I often convert leaf blower engines, and they tend to have huge mufflers that are 6" or more long and very heavy as well. These are the ones I cut down, gut, and then cap and add exit tubes. I generally use 1/2" or 3/4" copper tubing. It brazes well. In the past I have used thin wall K & S brass tubing, but it is really thin and tough to braze. It really should be silver soldered or silver brazed, but that's expensive!
AV8TOR
ID:	2046294   Click image for larger version
