Taped off the leading edges today for the yellow paint. Realized I was too far back initially as you can see in the picture of the wing bottom before paint. The yellow would have ended up on the gear doors so I moved the tape line back to just run by the gear door openings. The result can be seen in the painted wing bottom. Taped off the fuse for the two red stripes. To get these just right is a lot of work and measuring. Used as much blue tape as possible then the red Great Planes vinyl tape. Will get painted tomorrow. Panel lines, some silver wear marks, and panel lines to be done yet.
