The first question is...have you flown CL before? The reason for the question is if the answer is no, you probably want a BASIC trainer. Some of the planes mentioned would be a better STUNT trainer, after you have mastered round and round.
George
Hi George, This Basic trainer experience is what I'm trying to have the original poster avoid. My sons are not the only
new to C/L modelers to do simple aerobatics on their VERY FIRST control line flight. I can recall three adults that in their first
flight, did lazy eights, inside and outside loops and inverted flight(to them, inverted was just the other direction). One of those
adults was James Szhou, formerly of CS and Raptorz model engines. I'd like to point out that uninterrupted repetition of a
single maneuver such as the four-leaf clover is easy to master if you can do it for 20 minutes without refueling, without crashing.
Within an hour, you will be flying vertical and horizontal hourglasses. This will be my last rant in support of a beginner's first control line flying,
should should be with a stunt kite. I'm available to answer questions for anyone that wants to learn more about kite flying. Best Regards;
Tony
