Our new hangar/shop is a large shed next to 100 acres of flat cultivated fields with two runways. 20 minute drive away. So for starters I'll put in10cc of fuel and burn off 5cc walking to the edge of the field from inside..
The Profi .061 racer has been sitting in the wings as well, I reset the wing incidence, moved the CG forward, and replaced the NiMH with a 430 mAh 2S LiPo and a Novak regulator. It's ready to go too. The Rx battery alone is probably big enough to fly the thing around for a couple of minutes at 60mph.
