What servos were you three amigos using ?
I have two of the 831's and they work fine with Futaba (and JR) servos.
If you recall, the first batch of Futaba 2.4 receivers would not work with Hitec servos. The RX output voltage was not high enough to run the Hitec servos. Hitec could modify them to work by changing a pull up/down resister. A guy I fly with kept having glitches with a Futaba 6008HS and Hitec servos. Turned out Hitec replaced a motor in one of the servos. It was shorting and resetting the receiver.
All receivers and servos are not compatible. All receivers and BEC's/Regulators are not compatible. Are you running separate ignition packs?
