Hi Dave
Looks like JR have seen the gap and stepped up, It dose not look like the usual JR style of ancillary but I like the look of it, plus as its JR so its bound to be good quality. Having 14chs should certainly satisfy the XG14 users and make the 28chs of the 28Xs more worth wile. Having the duel power redundancy built in is a sensible touch, simple redundancy for HV and I guess duel regulators for the everything else. As far as I can tell this is not actually an Rx? but a 14ch X-Bus to PWM converter to be used with a pair of the 7ch Ex Bus RXs correct? Were I still a JR DMSS user I would have liked a proper 14ch Rx or even better the ability to use DMSS RXs in parallel in the same install and be able to spread the channels between them giving as many channels as is needed, that seems like the simplest solution to high channel counts. I've had a quick look online, this XBI-14DRS is not listed anywhere yet, Im sure the next post will be "any idea when it will be realised and ball park retail cost"
