Originally Posted by
vertical grimmace
There should be clear separation between types of models as they are so profoundly different. I could see it being perfectly acceptable to have FPV models be effected by a NOTAM, but conventional line of sight r/c be exempt. This will of course never happen unless there is a will for it to occur. As the line of sight models offer no REAL threat at all, due to such limited range. That is why we need separation of type of model. How ludicrous would it be to include a C/L model in a NOTAM? To me it is almost the same thing with the difference between line of sight R/C, and long range FPV.
Any type of model be it multi rotor or fixed wing can be flown with FPV, To me it's not the type of model that is the issue but where the model is operated
and is being done safely is the issue.
