RCU Forums - View Single Post - Weatronic 2.4 RF diagnostic tool
Old 11-22-2014 | 03:56 AM
  #2559
olnico's Avatar
olnico
Originally Posted by zl1wn
My next challenge is to work out that small curve edit screen for each servo. at this stage I dont think the presets are a lot of use, but time will tell.
The problem I have is trying to make the curves do what I need, Unlike gigacontrol where you have a large screen to deal with and it is easy with a mouse.
Ross
Hello Ross.
Editing the servo curve with the BAT UI is a different method than Gigacontrol. As easy to do in fact.
I like presets a lot. Most of the time I come to realize that I just need 4 points along the curve to align multiple flight controls. The preset gives me the ability to edit 4 points on the curve really easily.
Here is the method I use.
First enter the curve edit mode.
Then select the non-global option ( to edit the curve with point, not to move the whole curve ).
Then enter the preset menu.
Select the 4 point curve preset.
Then move the current point along the curve with your stick or knob till you reach the point you want to edit. It will highlight with a thin red circle.
Then hit the "select" button. The highlighted point will turn solid red.
Now you can adjust the output value with the "+" and "-" keys. Note that you will need to keep your stick at the current position to check the effect on the point live.
A complete curve can be edited quickly with this method.
