RCU Forums - View Single Post - Help..breaking in engine Hissing sounds
Old 10-09-2003 | 10:19 PM
nitrofan
Default RE: Help..breaking in engine Hissing sounds
The compression will be lower if the plug is loose, but thats not permanent. You'll gain it back if you tighten the plug. It usually takes about 1/8 turn after the plug bottoms out to get a good seal. You want it tight, but not too tight. Most heads/head buttons are aluminum, so you can strip the threads if you go gorilla on it, but give it a good snugging and try it again
