Also ther is going to be a big change in plans for my Yeti XL chassis that I was using. I will be changing it to Carbon fiber I plan on cutting a new Vantage chassis and adding carbon fiber to get the lenght that I will be needed.
Also the diffs are going to be beefed up by using Losi LST 2 diffs with thge aluminum housings.
This will then be able to take big power and large tires with no problems Hoping to make it light weight and bomb proof at the same time. I still plan on mounting the Hitec HS-5575MG servo. I want the build not only light as possible but strong as possible. Should be a bad boy RC Desert Buggy! I have been looking on the tower web site and the cage pieces can be had. I may go that route and and the factory plasic pannels later. I will make my own aluminum pannels and go from there. I should have the parts I need and have the build ready for Christmas. Time and money will tell. I'm trying to find Vantage carbon A-arms if anyone knows of any.
