RCU Forums - View Single Post - K&B .20 Help Needed Please
Old 11-23-2014 | 12:33 PM
Mr Cox's Avatar
Mr Cox
Yes it looks like a Perry carb that is on "backwards" (just rotate it 180°). The rotating disk is for the low end and it is very sensitive, minute adjustments is the key. The the lines indicate neutral position and maximum points for a leaner and richer settings, yes it doesn't need a larger span than that (!).
The mounting of the backplate is a little compromised but if it doesn't leak then the crankcase damage shouldn't matter.
