RCU Forums - View Single Post - Need help with two G26's
Old 10-09-2003 | 11:22 PM
grebmohr
Default RE: Need help with two G26's
I don't remember the speed rating- but I used to use a 5 mil aluminum tape that had around 60 ounce/inches of adhesion and a temp range from freezing to 325 degrees.
Does that sound like your tape? If it does you can buy it at aircraft parts supply houses. taped many a cessna fairing back on with it.
