Originally Posted by
acdii
Except for the metal, going to use the same dope I used for the rest of the plane since they are wood.
I would like to devise a way to quick attach the strut to the fuse so I dont have to mess with a nut and screw at the field, but maybe I can just epoxy the nut to the fitting and do it that way instead. I have a feeling this plane will be a blast to fly, just hope that 100 doesn't rip the wings off!
If it flies anything like that T-Clips I will love it, though I feel ground handling will be a wee bit better since it has a longer fuse.
Adjust the join at the fuselage so that the struts can be easily folded back toward the fin-rudder.
Then a small elastic can hold them together there.
Zor
